network arp active-entry show
Display active ARP entries organized by Vserver
The `network arp active-entry show ` command displays ARP entries present in the network stack of the node. The entries includes both dynamically learned ARP entries and user configured static ARP entries.
[-fields <fieldname>,…] -
Use this parameter to display only certain fields of the active ARP table.
[-instance ]} -
Use this parameter to display all the fields of the active ARP table.
 [-node {<nodename>|local}]- Node (privilege: advanced)-
Use this parameter to display active ARP entries that are specific to a given node.
 [-vserver <vserver>]- System or Admin Vserver Name (privilege: advanced)-
Use this parameter to display active ARP entries that are specific to a given System or Admin Vserver. Data and Node Vservers will not have any active-arp entries.
 [-subnet-group <IP Address/Mask>]- Subnet Group Name (privilege: advanced)-
Use this parameter to display active ARP entries that are specific to a given subnet group.
 [-remotehost <text>]- Remote IP Address (privilege: advanced)-
Use this parameter to display active ARP entries for the specified IP address.
 [-port <text>]- Port (privilege: advanced)-
Use this parameter to display active ARP entries for the specified Port name.
 [-mac <text>]- MAC Address (privilege: advanced)-
Use this parameter to display the active ARP entry for the specified MAC address.
 [-ipspace <IPspace>]- IPspace (privilege: advanced)-
Use this parameter to specify the IPspace associated with the System or Admin Vserver.
The following example displays active ARP entries for the Admin Vserver cluster1:
cluster1::*> network arp active-entry show -vserver cluster1 Node: node-01 Vserver: cluster1 Subnet Group: 169.254.0.0/16 Remote IP Address MAC Address Port ----------------- ----------------- ------- 169.254.106.95 0:55:39:27:d1:c1 lo
