ONTAP commands
lun copy pause
Pause an ongoing LUN copy operation
The lun copy pause command pauses an ongoing copy operation. Use the lun copy resume command to resume the copy operation.
Note LUNs cannot be copied to or from a Vserver with Infinite Volume.
{ -vserver <Vserver Name> - Vserver Name
Specifies the name of the Vserver that will host the destination LUN.
-destination-path <path> - Destination Path
Specifies the full path to the new LUN, in the format /vol/<volume>[/<qtree>]/<lun>.
cluster1::> lun copy pause -vserver vs1 -destination-path /vol/vol2/lun2
Pauses the ongoing copy operation identified by Vserver vs1 and destination path /vol/vol2/lun2 .
