ONTAP commands
vserver migrate show-progress
Display status of volumes in a migrating Vservers
This command displays data transfer progress of all the volumes in migrating Vservers.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
If this parameter is specified, the command displays detailed volume progress information.
[-vserver <vserver name>] - Vserver (privilege: advanced)
Name of the Vserver which is migrating.
[-volume <volume name>] - Volume Name (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified volume.
[-vserver-uuid <UUID>] - Vserver UUID (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified Vserver UUID.
[-source-cluster-uuid <UUID>] - Source Cluster Uuid (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified source cluster UUID.
[-bytes-transferred {<integer>[KB|MB|GB|TB|PB]}] - Bytes transferred per volume (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified bytes transferred.
[-bytes-to-be-transferred {<integer>[KB|MB|GB|TB|PB]}] - Bytes to be transferred per volume (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified bytes to be transferred.
[-transfer-rate <text>] - Rate of data transfers (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified transfer rate.
[-transfer-start-time <integer>] - Transfer start time (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified transfer start time.
[-total-bytes-to-be-transferred {<integer>[KB|MB|GB|TB|PB]}] - Total bytes to be transferred per vserver (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified total bytes to be transferred.
[-progress-time-last-updated <integer>] - Real time progress time given by SnapMirror (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified real time progress time given by snapmirror.
[-last-transfer-time <integer>] - Last trasnfer time (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified last transfer time.
[-progress-bytes-last-updated {<integer>[KB|MB|GB|TB|PB]}] - Real time progress bytes given by SnapMirror (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified real time progress bytes given by snapmirror.
[-time-remaining <text>] - Remaining time for bytes transfer (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified time remaining for bytes transfer.
[-percent-complete <percent>] - Percentage of transfer completed (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified percentage of transfer completed.
[-total-bytes-transferred {<integer>[KB|MB|GB|TB|PB]}] - Total bytes trasferred per vserver (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified total bytes transferred per vserver.
[-average-transfer-rate <text>] - Average transfer rate per vserver (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified average transfer rate per vserver.
[-total-time-remaining <text>] - Total Time Remaining per vserver (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified total time remaining per vsrever.
[-total-percent-complete <percent>] - Total Percent complete per vserver (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified total percent of transfer complete per vserver.
[-total-used {<integer>[KB|MB|GB|TB|PB]}] - Total Used (privilege: advanced)
If this parameter is specified, the command displays the details of volume progress that matches specified total used size.
cluster1::> vserver migrate show-progress -vserver test
Looking for answers?
Try Doc, our Gen AI Assistant.
