network interface capacity details show
PDF of this doc site
Creating your file...
Display details about the IP data LIFs capable of being configured on each node.
The network interface capacity details show
command displays the number of IP LIFs of role data
that can be configured on each node, the number of IP data LIFs of role data
that are supported on each node, and the number of IP data LIFs of role data
that are configured to be homed on each node.
The number of IP LIFs of role data that are supported on a node depends on the hardware platform and the Cluster's Data ONTAP version. If one or more nodes in the cluster cannot support additional LIFs, then none of the nodes in the cluster can support additional LIFs.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
Use this parameter to specify the node for which to obtain data LIF capacity.
[-capacity-for-node <integer>]
- Number of IP data LIFs that can be configured on the node-
This parameter specifies the number of IP LIFs of role
data
that can be configured on the node at the currently running Data ONTAP version. To view the version of a node, use the cluster image show command. [-limit-for-node <integer>]
- Number of IP data LIFs that are supported on the node-
data
that are supported on the node at the current effective cluster version (ECV). To view the version of a node, use the cluster image show command. [-count-for-node <integer>]
- Number of IP data LIFs that are assigned to the node-
data
currently configured to be homed on the node. To view LIFs homed on this node, use the network interface show -home-node command.
The following displays the IP data LIF capacity.
cluster1::> network interface capacity details show IP Data LIF IP Data LIF IP Data LIF Node Capacity Supported Limit Count ----------------- --------------- --------------- --------------- node1 512 512 128 node2 512 512 128
