network interface failover-groups show
Display logical interface failover groups
The network interface failover-groups show command displays information about logical interface failover groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver Name-
Use this parameter to display information only about the logical interface failover groups that have the target Vserver you specify.
[-failover-group <text>]- Failover Group Name-
Use this parameter to display information only about the logical interface failover groups you specify.
[-targets [node>:<port],…]- Failover Targets-
Use this parameter to display information only about the logical interface failover groups that have the failover target (physical port, interfacde group, or VLAN) you specify.
[-broadcast-domain <broadcast domain name>]- Broadcast Domain-
Use this parameter to display information only about the logical interface failover groups that have the broadcast domain you specify.
The following example displays information about all logical interface failover groups on a two node cluster.
cluster1::> network interface failover-groups show
Failover
Vserver Group Targets
Cluster
Cluster
node1:e1a, node1:e2a,
node2:e1a, node2:e2a,
cluster1
Default
node1:e0M, node1:e0a,
node1:e0b, node1:e0c,
node1:e0d, node2:e0M,
node2:e0a, node2:e0b,
node2:e0c, node2:e0d
