security session limit request modify
Modify per-request session limit
This command allows modification of a per-request management session limit.
-interface {cli|ontapi}- Interface (privilege: advanced)-
The interface (CLI or ONTAPI) to which the limit applies.
-request <text>- Request Name (privilege: advanced)-
The specified request to which this limit applies. The limit with the request name
-default-is the limit used for any request without a specific configured limit. [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and request.
The following example illustrates modifying the limit of the number of clients simulatiously executing a specific API.
cluster1::*> security session limit request modify -interface ontapi -request storage-disk-get-iter -max-active-limit 4
