system license show-status
Display license status
This command displays the status of all Data ONTAP licenses.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-status {not-compliant|eval|partially-installed|valid|not-installed|not-applicable}]- Current state-
If you use this parameter, the command displays information only about licenses that match the given status.
[-license <Licensable Package>]- License-
If you use this parameter, the command displays information only about licenses that match the given license.
[-scope {site|cluster|node}]- License Scope-
If you use this parameter, the command displays information only about licenses that match the given scope.
[-detailed-status <text>,…]- Detailed Status-
If you use this parameter, the command displays information only about licenses that match the given detailed-status.
The following example displays the license status of the cluster:
cluster1::> system license show-status
Status License Scope Detailed Status
partially-installed
CIFS node License missing on: Node2-Cluster1.
SnapRestore node License missing on: Node2-Cluster1.
valid
FCP node -
FabricPool cluster The system is using 1TB, and can use up to 25TB.
not-installed
NFS - -
iSCSI - -
SnapMirror - -
FlexClone - -
SnapVault - -
SnapLock - -
SnapManagerSuite - -
SnapProtectApps - -
V_StorageAttach - -
Insight_Balance - -
OCShift - -
TPM - -
VE - -
DP_Optimized - -
not-applicable
Cloud - -
Select - -
20 entries were displayed.
