volume reallocation stop
Stop reallocate job
Stops and deletes any reallocation scans on a LUN, file, or volume. This command stops and deletes in-progress, scheduled, and quiesced scans.
This command is not supported for FlexGroups, FlexGroup constituents, Infinite Volumes, or Infinite Volume constituents. |
-vserver <vserver name>- Vserver-
Specifies the Vserver.
-path <text>- Path-
Specifies the path of the reallocation for a LUN, file, or volume.
cluster1::> volume reallocation stop /vol/vol2 1 entry was deleted.
Stops and deletes one reallocation scan on volume vol2.
