storage shelf acp module show
Show modules connected to the cluster
Displays information about the modules connected to each node
[-fields <fieldname>,…] -
If you specify the -fields <field-name>", … parameter, the command output also includes the specified field or fields. You can use '-fields ?' to dis play the fields to specify
[-errors ] -
If you specify the -errors parameter, the command displays detailed information about all modules with errors.
[-instance ]} -
[-node {<nodename>|local}]- Node-
Selects the modules that match this parameter value.
[-mac-address <text>]- MAC Address-
Selects the module that match the specified MAC address.
[-module-name <text>]- Module name-
Selects the module that match the specified module name.
[-module-address <IP Address>]- IP Address-
Selects the module that match the specified IP address.
[-protocol-version <text>]- Protocol Version-
Selects the modules that match the specified protocol version.
[-firmware-version <text>]- Firmware Version-
Selects the modules that match the specified firmware version.
[-acpa-id <integer>]- ACPA assigner ID-
Selects the modules that match the specified ACPA ID.
[-shelf-serial-number <text>]- Shelf Serial Number-
Selects the modules that match the specified shelf serial number.
[-iom-type {Unknown|iom3|iom6|iom6e|iom12|iom12e|iom12f}]- IOM Type-
Selects the modules that match the specified IOM type (IOM3/IOM6/IOM6E).
[-last-contact <integer>]- Last Contact (secs)-
Selects the modules that match the specified last contact.
[-state {unknown|initializing|discovery-complete|awaiting-inband|no-inband|active|awaiting-bootp|updating-firmware|connection-error|firmware-update-required|rebooting|fail|unsupported|degraded|shelf-off}]- Local Node State-
Selects the modules that match the specified state.
[-stack-id {<integer>|-}]- Stack ID-
Selects the modules that match the specified stack ID.
[-shelf-id <text>]- Shelf ID-
Selects the modules that match the specified shelf ID.
[-adapter-name <text>]- Adapter Name-
Selects the modules that match the specified adapter name.
[-error-id <integer>,…]- Error ID-
Selects the modules that match the specified error ID.
[-error-text <text>,…]- Error Text-
The error text, in case of a module error.
[-corrective-action <text>,…]- Corrective Action-
The corrective action, in case of a module error.
[-error-type {No-Error|Connection-Issue|Connection-Activity|Module-Error|Shelf-Error}]- Error Type-
Selects the modules that match the specified error type.
[-error-severity {unknown|notice|warning|error|critical}]- Error Severity-
Selects the modules that match the specified error severity.
The following example displays the ACP modules connected to each node:
cluster1::> storage shelf acp module show
Node Module Name State
stor-v4-1a-1b-01 1.10.A Active
1.10.B Active
1.254.B Active
1.254.A Active
stor-v4-1a-1b-02 1.10.A Active
1.10.B Active
1.254.B Active
1.254.A Active
8 entries were displayed.
The following example displays the -instance output of the storage shelf acp module show. More details on each module can be seen here.
cluster1::> storage shelf acp module show -instance
Node: stor-v4-1a-1b-01
Module Name: 1.10.A
Mac Address: 00:a0:98:19:53:ee
IOM Type: IOM6E
Shelf Serial Number: SHJMS000000001A
IP Address: 192.168.3.239
Protocol Version: 2.1.1.21
Assigner ID: 2.1.1.21
State: Active
Last Contact: 203
Module Name: 1.10.B
Mac Address: 00:a0:98:19:55:16
IOM Type: IOM6E
IP Address: 192.168.1.23
State: Active
Last Contact: 206
Module Name: 1.254.B
Mac Address: 00:a0:98:32:d6:ac
IOM Type: IOM6
Shelf Serial Number: 6000368103
IP Address: 192.168.2.173
Protocol Version: 1.2.2. 8
Assigner ID: 1.2.2. 8
State: Active
Last Contact: 215
Module Name: 1.254.A
Mac Address: 00:a0:98:32:d6:dc
IOM Type: IOM6
IP Address: 192.168.2.221
State: Active
Last Contact: 218
Node: stor-v4-1a-1b-02
Module Name: 1.106.A
IOM Type: IOM6E
State: Initializing
Last Contact: 206
Module Name: 1.106.B
IOM Type: IOM6E
State: Initializing
Last Contact: 209
Module Name: 1.10.B
IOM Type: IOM6
Protocol Version: 1.2.2.8
Assigner ID: 1.2.2.8
State: Initializing
Last Contact: 217
Module Name: 1.10.A
IOM Type: IOM6
State: Initializing
Last Contact: 220
