storage shelf acp module show
Show modules connected to the cluster
Displays information about the modules connected to each node
- { [-fields <fieldname>,…]
If you specify the -fields <field-name>", … parameter, the command output also includes the specified field or fields. You can use '-fields ?' to dis play the fields to specify
- | [-errors ]
If you specify the -errors parameter, the command displays detailed information about all modules with errors.
- | [-instance ]}
- [-node {<nodename>|local}]- Node
Selects the modules that match this parameter value.
- [-mac-address <text>]- MAC Address
Selects the module that match the specified MAC address.
- [-module-name <text>]- Module name
Selects the module that match the specified module name.
- [-module-address <IP Address>]- IP Address
Selects the module that match the specified IP address.
- [-protocol-version <text>]- Protocol Version
Selects the modules that match the specified protocol version.
- [-firmware-version <text>]- Firmware Version
Selects the modules that match the specified firmware version.
- [-acpa-id <integer>]- ACPA assigner ID
Selects the modules that match the specified ACPA ID.
- [-shelf-serial-number <text>]- Shelf Serial Number
Selects the modules that match the specified shelf serial number.
- [-iom-type {Unknown|iom3|iom6|iom6e|iom12|iom12e|iom12f|iom12b|iom12g|iom12c}]- IOM Type
Selects the modules that match the specified IOM type (IOM3/IOM6/IOM6E).
- [-last-contact <integer>]- Last Contact (secs)
Selects the modules that match the specified last contact.
- [-state {unknown|initializing|discovery-complete|awaiting-inband|no-inband|active|awaiting-bootp|updating-firmware|connection-error|firmware-update-required|rebooting|fail|unsupported|degraded|shelf-off}]- Local Node State
Selects the modules that match the specified state.
- [-stack-id {<integer>|-}]- Stack ID
Selects the modules that match the specified stack ID.
- [-shelf-id <text>]- Shelf ID
Selects the modules that match the specified shelf ID.
- [-adapter-name <text>]- Adapter Name
Selects the modules that match the specified adapter name.
- [-error-id <integer>,…]- Error ID
Selects the modules that match the specified error ID.
- [-error-text <text>,…]- Error Text
The error text, in case of a module error.
- [-corrective-action <text>,…]- Corrective Action
The corrective action, in case of a module error.
- [-error-type {No-Error|Connection-Issue|Connection-Activity|Module-Error|Shelf-Error}]- Error Type
Selects the modules that match the specified error type.
- [-error-severity {unknown|notice|warning|error|critical}]- Error Severity
Selects the modules that match the specified error severity.
- [-power-cycle-count <integer>]- Power Cycle count
Number of times a shelf power cycle has been performed on a shelf
- [-power-off-count <integer>]- Power Off count
Number of times a shelf power off has been performed on a shelf
- [-power-on-count <integer>]- Power On count
Number of times a shelf power on has been performed on a shelf
- [-expander-reset-count <integer>]- Expander reset count
Number of times an expander reset has been performed on a module
- [-expander-power-cycle-count <integer>]- Expander power cycle count
Number of times an expander power cycle has been performed on a module
The following example displays the ACP modules connected to each node:
cluster1::> storage shelf acp module show
Node               Module Name        State
stor-v4-1a-1b-01   1.10.A             Active
                   1.10.B             Active
                   1.254.B            Active
                   1.254.A            Active
stor-v4-1a-1b-02   1.10.A             Active
                   1.10.B             Active
                   1.254.B            Active
                   1.254.A            Active
8 entries were displayed.
The following example displays the -instance output of the storage shelf acp module show. More details on each module can be seen here.
cluster1::> storage shelf acp module show -instance
Node: stor-v4-1a-1b-01
               Module Name: 1.10.A
               Mac Address: 00:a0:98:19:53:ee
                  IOM Type: IOM6E
       Shelf Serial Number: SHJMS000000001A
                IP Address: 192.168.3.239
          Protocol Version: 2.1.1.21
               Assigner ID: 2.1.1.21
                     State: Active
              Last Contact: 203
         Power Cycle Count: 0
           Power Off Count: 0
            Power On Count: 0
      Expander Reset Count: 0
Expander Power Cycle Count: 0
               Module Name: 1.10.B
               Mac Address: 00:a0:98:19:55:16
                  IOM Type: IOM6E
                IP Address: 192.168.1.23
                     State: Active
              Last Contact: 206
           Power Off Count: 0
            Power On Count: 0
               Module Name: 1.254.B
               Mac Address: 00:a0:98:32:d6:ac
                  IOM Type: IOM6
       Shelf Serial Number: 6000368103
                IP Address: 192.168.2.173
          Protocol Version: 1.2.2. 8
               Assigner ID: 1.2.2. 8
                     State: Active
              Last Contact: 215
           Power Off Count: 0
            Power On Count: 0
               Module Name: 1.254.A
               Mac Address: 00:a0:98:32:d6:dc
                  IOM Type: IOM6
                IP Address: 192.168.2.221
                     State: Active
              Last Contact: 218
           Power Off Count: 0
            Power On Count: 0
Node: stor-v4-1a-1b-02
               Module Name: 1.106.A
                  IOM Type: IOM6E
                     State: Initializing
              Last Contact: 206
           Power Off Count: 0
            Power On Count: 0
               Module Name: 1.106.B
                  IOM Type: IOM6E
                     State: Initializing
              Last Contact: 209
           Power Off Count: 0
            Power On Count: 0
               Module Name: 1.10.B
                  IOM Type: IOM6
          Protocol Version: 1.2.2.8
               Assigner ID: 1.2.2.8
                     State: Initializing
              Last Contact: 217
           Power Off Count: 0
            Power On Count: 0
               Module Name: 1.10.A
                  IOM Type: IOM6
                     State: Initializing
              Last Contact: 220
           Power Off Count: 0
            Power On Count: 0
 PDFs
PDFs
