volume file show-filehandle
Show the file handle of a file
This command requires a path to a file in a volume and displays the file handle information described below:
  • Vserver name
  • Path to the file
  • File handle flags
  • Snapshot ID of the file (snapid)
  • File ID
  • File handle generation number
  • File system ID (fsid)
  • Master data set ID (msid)
  • Data set ID (dsid)
If not logged in as a Vserver administrator, the command also requires a Vserver name.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Managing Volume (privilege: advanced)
This specifies the Vserver where the file resides.
[-path <text>] - Path to File (privilege: advanced)
This specifies the path to the file.
The following example displays the file handle information of a file named file1.txt in the volume /vol/vol1 .
cluster1::> volume file show-filehandle -vserver vs0 -path /vol/vol1/file1.txt
             Vserver                    Path
             vs0                         /vol/vol1/file1.txt
flags   snapid  fileid     generation  fsid        msid          dsid
             0x0     0       0x60       0x206b6     0x402       0x80000402    0x402
