volume move recommend show
Display Move Recommendations
The volume move recommend show command displays moves that were recommended by the Auto Balance Aggregate feature.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter is specified, the display will be limited to only those recommendations with a Vserver that matches the specified value.
[-volume <volume name>] - Volume Name
If this parameter is specified, the display will be limited to only those recommendations with a volume that matches the specified value.
[-creation-time <MM/DD/YYYY HH:MM:SS>] - Time Stamp of Recommendation
If this parameter is specified, the display will be limited to only those recommendations with a creation-time that matches the specified value.
[-source-aggregate <aggregate name>] - Unbalanced Aggregate Name
If this parameter is specified, the display will be limited to only those recommendations with a source-aggregate that matches the specified value.
[-source-space-after <percent>] - Space Free After Move (%)
If this parameter is specified, the display will be limited to only those recommendations with a source-space-after that matches the specified value.
[-destination-aggregate <aggregate name>] - Destination Aggregate Name
If this parameter is specified, the display will be limited to only those recommendations with a destination-aggregate that matches the specified value.
[-destination-space-after <percent>] - Space Bump After Move (%)
If this parameter is specified, the display will be limited to only those recommendations with a destination-space-after that matches the specified value.
The following example displays information about the recommendations made by the Auto Balance Aggregate feature.
cluster1::*> volume move recommend show -instance
                   Vserver Name: vs0.example.com
                    Volume Name: ro10
   Time Stamp of Recommendation: 3/13/2014 16:26:39
      Unbalanced Aggregate Name: aggr_1
      Space Free After Move (%): 36%
     Destination Aggregate Name: aggr_3
      Space Bump After Move (%): 36%
