volume flexgroup deploy
Deploy a FlexGroup on the cluster
The volume flexgroup deploy command deploys a FlexGroup on the cluster.
The FlexGroup is created with 8 constituents on each node in the cluster. The constituents are split equally between the two largest aggregates on each node. If using two aggregates per node is not possible, all of the constituents are created on the largest aggregate on each node.
The volume flexgroup deploy command is only supported on clusters with 4 nodes or less. On clusters with more than 4 nodes, use the volume create command to create FlexGroups.
-vserver <vserver name>- Vserver Name-
This specifies the Vserver on which the FlexGroup will be located.
-size {<integer>[KB|MB|GB|TB|PB]}- Size of the FlexGroup-
This specifies the size of the FlexGroup. The size is specified as a number followed by a unit designation: k (kilobytes), m (megabytes), g (gigabytes), t (terabytes), or p (petabytes). If the unit designation is not specified, bytes are used as the unit and the specified number is rounded up to the nearest 4 KB. The minimum size is 160 MB multiplied by the number of nodes in the cluster. The maximum size of the FlexGroup is limited by the platform maximum FlexVol size multiplied by 8 and multiplied by the number of nodes in the cluster. The size of the FlexGroup is also limited by the available space in the hosting aggregates. FlexGroups can be increased in size with the volume modify command and more constituents can be added with the volume expand command.
[-volume <volume name>]- Name of the FlexGroup to Create-
This specifies the name of the FlexGroup. The name of the FlexGroup must start with an alphabetic character (a to z or A to Z) and must have 197 or fewer characters. The default value for the FlexGroup name is "fg".
[-type {RW|DP}]- Volume Type-
This optionally specifies the FlexGroup's type, either read-write (RW) or data-protection (DP). If you do not specify a value for this parameter, a RW volume is created by default.
[-space-guarantee {none|volume}]- Space Guarantee Style-
This optionally specifies the space guarantee style for the FlexGroup. A value of
volumereserves space on the aggregates for the entire volume. A value ofnonereserves no space on the aggregates, meaning that writes can fail if an aggregate runs out of space. Because CIFS does not handle out-of-space conditions, do not use the valuenoneif the volume is accessible to CIFS clients. The default setting for volumes on All Flash FAS systems isnone, otherwise the default setting isvolume. [-foreground {true|false}]- Foreground Process-
If this parameter is specified with
false, the command runs in the background as a job. Otherwise, the command does not return until the operation is complete. The default value istrue
The following example deploys a FlexGroup named "flexgroup" in the Vserver named "vs1.example.com":
cluster::> volume flexgroup deploy -size 400TB -vserver vs1.example.com -volume flexgroup
