storage aggregate object-store show
Display the details of object stores attached to an aggregate
The storage aggregate object-store show command displays information about all the object stores in the system.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <text>]- Aggregate Name-
If this parameter is specified, the command displays information only about the object stores that are attached to the specified aggregates.
[-object-store-name <text>]- ONTAP Name for this Object Store Config-
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
[-object-store-availability <object Store Availability>]- Availability of the Object Store-
If this parameter is specified, the command displays information only about object stores whose availability status matches the specified value. Supported values with this parameter are - available and unavailable.
[-license-used-percent <percent_no_limit>]- License Space Used Percent-
If this parameter is specified, the command displays information only about object stores whose space used by the aggregate as a percentage of the license limit matches the specified value.
The following example displays all information about all object stores:
cluster1::>storage aggregate object-store show
