      security key-manager delete-key-database
Deletes the key hierarchy for onboard key manager
The security key-manager delete-key-database command permanently deletes the onboard key-management configuration from all nodes of the cluster.
The following example deletes the onboard key-management configuration from all nodes of the cluster:
cluster-1::*> security key-manager delete-key-database
Warning: This command will permanently delete all keys from onboard key management.
Do you want to continue? {y|n}: y
