system node internal-switch dump port-mapping
Display onboard switch port mapping
The system node internal-switch dump port-mapping command is used to show the internal switch port connections.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node-
Use this parameter to specify the node the switch resides on.
[-switch-id <integer>]- Switch-
Use this parameter to specify the switch id. For example, 1.
[-port-id <integer>]- Port-
Use this parameter to specify the port id. For example, 0.
[-role <text>]- Port Name-
Use this parameter to specify the port name. For example, e0M.
The following example shows the port connections of the internal switch 0 on Node1.
cluster1::> system node internal-switch dump port-mapping -node Node1 -switch-id 0 Port Port Name ---- ----------------- Node: Node1 , Switch: 0 0 sw-wrench 1 sw-locked-wrench 2 sw-e0M 3 sw-e0P 4 sw-midplane-1 5 sw-expander-1 6 sw-sp-1 7 entries were displayed.
