storage shelf location-led modify
Modify the state of the shelf Location LED
The storage shelf location-led modify command modifies the on/off state of the shelf location LED.
-shelf-name <text> - Shelf Name
This parameter specifies the shelf whose LED is to be turned on or turned off.
[-led-status {on|off}] - Location LED
This parameter specifies whether the shelf location LED needs to be turned on or turned off.
The following example turns on the shelf location LED of the specified shelf.
cluster1::> storage shelf location-led modify -node node1 -shelf-name 1.0 -led-status on
Info: Shelf locate request successful for shelf "1.0".
The following example turns off the shelf location LED of the specified shelf.
cluster1::> storage shelf location-led modify -node node1 -shelf-name 1.0 -led-status off
