vserver peer transition show
Display transition peer relationships.
The vserver peer transition show command displays the following information about transition peer transition relationships:
Local Vserver name
Source 7-Mode system
Multi-path address
Local LIFs
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-local-vserver <vserver name>]- Local Vserver name-
If this parameter is specified, the command displays transition peer information about the specified local Vserver.
[-src-filer-name <text>]- Source 7-Mode system-
If this parameter is specified, the command displays transition peer information about the specified source 7-Mode system.
[-multi-path-address <text>]- Additional address for source 7-Mode system-
If this parameter is specified, the command displays information about the specified multipath-address.
[-local-lifs <lif-name>,…]- List of Local LIFs-
If this parameter is specified, the command displays information about the specified local LIFs.
cluster1::> vserver peer transition show
Vserver Source Filer Multi Path Address Local LIFs
vs1.example.com lif1, lif2
src1.example.com
src1-e0b.example.com
