vserver iscsi isns show
- PDF of this doc site
Creating your file...
Show iSNS service configuration
Shows the iSNS service configuration.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the iSNS services that match the Vserver name that you specify.
[-address <IP Address>]
- iSNS Server IP Address-
Use this parameter to display the iSNS services that match the IP address of the iSNS server that you specify.
[-status-admin {down|up}]
- Administrative Status-
Use this parameter to display the iSNS services that match the configured status of the service that you specify.
[-entity-id <text>]
- iSNS Server Entity Id-
Use this parameter to display the iSNS services that match the configured iSNS server entity-id that you specify.
[-last-successful-update <MM/DD/YYYY HH:MM:SS>]
- Last Successful Update-
Use this parameter to display the iSNS services that match the time of the last successful attempt.
[-last-update-attempt <MM/DD/YYYY HH:MM:SS>]
- Last Update Attempt-
Use this parameter to display the iSNS services that match the time of the last update attempt.
[-last-update-result <isnsErrors>]
- Last Update Result-
Use this parameter to display the iSNS services that match the result of the last update attempt.
cluster1::> vserver iscsi isns show Vserver iSNS Server Entity Identifier iSNS Server IP Address iSNS Status ---------- ------------------------------- ---------------------- ----------- iscsi_vs isns:00000044 10.229.136.188 up
Displays the output of the show command for all Vservers in a cluster.
cluster1::> vserver iscsi isns show -instance Vserver Name: vs1 iSNS Server IP Address: 10.72.19.11 Administrative Status: up iSNS Server Entity Id: isns.0000001c Last Successful Update: 11/12/2011 10:18:45 Last Update Attempt: 11/12/2011 10:18:45 Last Update Result: iSNS_Ok Vserver Name: vs2 iSNS Server IP Address: 10.72.16.13 Administrative Status: up iSNS Server Entity Id: isns.0000001b Last Successful Update: 11/12/2011 13:38:05 Last Update Attempt: 11/12/2011 13:38:05 Last Update Result: iSNS_Ok 2 entries were displayed.
Displays the details for all Vservers in a cluster.
