vserver iscsi isns show
Show iSNS service configuration
Shows the iSNS service configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the iSNS services that match the Vserver name that you specify.
[-address <IP Address>] - iSNS Server IP Address
Use this parameter to display the iSNS services that match the IP address of the iSNS server that you specify.
[-status-admin {down|up}] - Administrative Status
Use this parameter to display the iSNS services that match the configured status of the service that you specify.
[-entity-id <text>] - iSNS Server Entity Id
Use this parameter to display the iSNS services that match the configured iSNS server entity-id that you specify.
[-last-successful-update <MM/DD/YYYY HH:MM:SS>] - Last Successful Update
Use this parameter to display the iSNS services that match the time of the last successful attempt.
[-last-update-attempt <MM/DD/YYYY HH:MM:SS>] - Last Update Attempt
Use this parameter to display the iSNS services that match the time of the last update attempt.
[-last-update-result <isnsErrors>] - Last Update Result
Use this parameter to display the iSNS services that match the result of the last update attempt.
cluster1::> vserver iscsi isns show
Vserver    iSNS Server Entity Identifier   iSNS Server IP Address iSNS Status
iscsi_vs   isns:00000044                   10.229.136.188         up
Displays the output of the show command for all Vservers in a cluster.
cluster1::> vserver iscsi isns show -instance
          Vserver Name: vs1
iSNS Server IP Address: 10.72.19.11
 Administrative Status: up
 iSNS Server Entity Id: isns.0000001c
Last Successful Update: 11/12/2011 10:18:45
   Last Update Attempt: 11/12/2011 10:18:45
    Last Update Result: iSNS_Ok
Vserver Name: vs2
iSNS Server IP Address: 10.72.16.13
 iSNS Server Entity Id: isns.0000001b
Last Successful Update: 11/12/2011 13:38:05
   Last Update Attempt: 11/12/2011 13:38:05
2 entries were displayed.
Displays the details for all Vservers in a cluster.
