system controller sp config show
Display the Service Processor Config Table
The system controller sp config show command displays the following configuration information of the service processor for all nodes in the cluster:
  • Node name
  • Service processor status
  • Service processor firmware version
  • Booted firmware version
  • Service processor configuration status
  • Physical Ethernet link status of service processor
  • Health monitor status
To display more details, use the -instance parameter. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported.
{ [-fields <fieldname>,…​]
Selects the field that you specify.
| [-instance ] }
Displays detailed configuration information of the service processor.
[-node {<nodename>|local}] - Node
Use this parameter to list the service processor configuration of the specific node.
[-version <text>] - Firmware Version
Selects the service processor configuration with the specified firmware version.
[-boot-version {primary|backup}] - Booted Version
Selects the service processor configuration with the specified version of the currently booted partition.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example}] - Health Monitor Name
Selects the service processor configuration with the specified monitor name.
[-sp-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}] - SP Status
Selects the service processor configuration with the specified status of service processor.
[-sp-config {true|false}] - Auto Update Configured
Selects information about the service processor with the specified configuration status of the service processor.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Status
Selects the service processor configuration information with the specified service processor status.
[-link-status {up|down|disabled|unknown}] - Public Link Status
Selects the service processor configuration with the specified physical ethernet link status.
[-name <text>] - Display Name
Selects the service processor configuration with the specified unique name.
The example below displays configuration of the service processor in all the nodes in the cluster:
cluster1::> system controller sp config show
      Firmware   Booted    Auto Update  SP       Link
Node  Version    Version   Configured   Status   Status    Status
node1  2.2.2     primary   true         online   up        ok
node2  2.2.2     primary   true         online   up        ok
The example below displays configuration of the service processor of a particular node in detail:
cluster1::> system controller sp config show -instance -node node1
                  Node: node1
      Firmware Version: 2.2.2
        Booted Version: primary
   Health Monitor Name: controller
             SP Status: online
Auto Update Configured: true
                Status: ok
    Public Link Status: up
          Display Name: SP Config
