system cluster-switch show
Display the configuration for cluster and management switches
The system cluster-switch show command displays configuration details for the monitored cluster switches and management switches.
[-fields <fieldname>,…] -
Selects the fields that have the specified name.
[-snmp-config ] -
Displays the following information about a switch:
Device Name
SNMPv2c Community String or SNMPv3 Username
SNMP Version
[-status ] -
Displays the following status information about a switch:
Is Discovered
Model Number
Switch Network
Software Version
Reason For Not Monitoring
Source Of Switch Version
Is Monitored ?
[-instance ]} -
Selects detailed information for all the switches.
[-device <text>]- Device Name-
Selects the switches that match the specified device name.
[-address <IP Address>]- IP Address-
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version-
Selects the switches that match the specified SNMP version.
[-is-discovered {true|false}]- Is Discovered-
Selects the switches that match the specified discovery setting.
[-community <text>]- DEPRECATED-Community String or SNMPv3 Username-
This parameter is deprecated and may be removed in a future release of Data ONTAP. Use -community-or-usernameinstead.Selects the switches that match the specified SNMPv2c community string or SNMPv3 username.
[-community-or-username <text>]- Community String or SNMPv3 Username-
[-model {NX5010|NX5020|CAT2960|OTHER|NX5596|CN1610|CN1601|NX3132|OT5548|NX3132V|OT9332|NX3132XL}]- Model Number-
Selects the switches that match the specified model number.
[-type {cluster-network|management-network}]- Switch Network-
Selects the switches that match the specified switch type.
[-sw-version <text>]- Software Version-
Selects the switches that match the specified software version.
[-reason <text>]- Reason For Not Monitoring-
Selects the switches that match the specified reason.
[-version-source <text>]- Source Of Switch Version-
Selects the switches that match the specified version source (for example, from SNMP, CDP or ISDP).
[-is-monitoring-enabled-operational {true|false}]- Is Monitored ?-
Selects the switches that match the specifed operational monitoring status.
[-serial-number <text>]- Serial Number of the Device-
Selects the switches that match the specified serial number.
cluster1::> system cluster-switch show
Switch Type Address Model
cn1610-143--234 cluster-network 10.238.143.234 CN1610
Serial Number: 20211200007
Is Monitored: true
Reason:
Software Version: 1.1.0.1
Version Source: ISDP
cn1601--143-230 management-network 10.238.143.230 CN1601
Serial Number: 20210200019
Is Monitored: false
Reason: Monitoring Disabled by Default
cn1601--143-232 management-network 10.238.143.232 CN1601
Serial Number: 20210200017
Is Monitored: false
cn1610-143--231 cluster-network 10.238.143.231 CN1610
Serial Number: 20211200002
Is Monitored: true
Reason:
The example above displays the configuration of all cluster switches and management switches.
cluster1::> system cluster-switch show -snmp-config
SNMPv2c Community
Switch or SNMPv3 Username SNMP Version
SwitchA public SNMPv2c
The example above displays the SNMPv2c community string or SNMPv3 username and SNMP version for all cluster switches and management switches.
