vserver fcp nameserver show
Display FCP fabric name server entries
This command show entries in the fabric name server database.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
Use this parameter to select the Vservers that contain FCP LIFs.
- [-lif <text>]- LIF Name
Use this parameter to select the FCP LIFs.
- [-port-id <integer>]- Port Identifier
Use this parameter to select the assigned port identifier of the LIF.
- [-unzoned <true>]- Show unzoned name server entires
Use this parameter to show unzoned name server information.
- [-port-type <text>]- Port Type
Use this parameter to select the port type of the LIF.
- [-port-wwn <text>]- Port WWN
Use this parameter to select World Wide Port Name (WWPN) of the LIF.
- [-fabric-port-wwn <text>]- Fabric Port WWN
Use this parameter to select the fabric World Wide Port Name (WWPN) of the lif.
- [-node-wwn <text>]- Node WWN
Use this parameter to select the World Wide Node Name (WWNN) of the LIF.
- [-service-class <text>]- Service Class
Use this parameter to select the registered class of services as defined in the FC-FS standard.
- [-fc4-type <text>]- FC4 Type
Use this parameter to select the registered FC4 type.
- [-switch-port <text>]- Switch Port
Use this parameter to select the name of switch port connected to target array.
cluster1::> vserver fcp nameserver show
                                                     Port     Port         FC4
        Vserver:Lif         Node WWN, Port WWN       Id       Type         Type
        vs1 :lif1
                           20:00:00:a0:98:55:73:38
                           20:01:00:a0:98:55:73:38   8130561  N-Port       FCP
                           20:00:00:90:fa:73:12:dd
                           10:00:00:90:fa:73:12:dd   8194560  N-Port
        vs1 :lif2
                           20:00:00:90:fa:94:29:ee
                           10:00:00:90:fa:94:29:ee   8201984  N-Port       FCP
        3 entries were displayed.
 PDFs
PDFs
