vserver cifs superuser show
Display superuser permissions for CIFS accounts
The vserver cifs superuser show command displays all account names with superuser privileges. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following superuser information for all CIFS servers:
  • Vserver name
  • CIFS server NetBIOS name
  • Domain
  • Account Name
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays superuser information of only the specified Vservers.
[-domain <CIFS domain>] - Domain
If you specify this parameter, the command displays superuser information of only for accounts that are in the specified domain.
[-accountname <CIFS account>] - User
If you specify this parameter, the command displays superuser information of only the CIFS servers with the specified superuser account.
[-cifs-server <NetBIOS>] - CIFS Server NetBIOS Name
If you specify this parameter, the command displays superuser information of only the Vservers with specified CIFS server name.
The following example displays superuser information of all Vservers.
vs1::> vserver cifs superuser show
Vserver        CIFS Server     Domain          Account Name
vs1            SMB_SERVER1     CIFSDOMAIN      ADMINISTRATOR
vs2            SMB_SERVER2     CIFSDOMAIN      ADMINISTRATOR
