snapmirror protect
Start protection for volumes
The snapmirror protect command establishes SnapMirror protection for a list of volumes. For each volume, the command creates a data protection destination volume in the Vserver specified by the -destination-vserver parameter, creates an extended data protection (XDP) SnapMirror relationship, and starts the initialization of the SnapMirror relationship. This command must be used from the destination Vserver or cluster. This command is not supported for Infinite Volumes or Infinite Volume constituents, FlexGroup volumes or FlexGroup volume constituents, Vserver endpoints or non ONTAP endpoints.
-path-list {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>}- Path List-
This parameter specifies the list of volumes to be protected. The list is a comma separated list of paths of the form
vserver:volume, for examplevs1.example.com:dept_eng1, vs1.example.com:dept_eng2 [-destination-vserver <vserver name>]- Destination Vserver-
This parameter specifies the Vserver in which to create the destination volumes of the SnapMirror relationships.
[-schedule <text>]- SnapMirror Schedule-
This optional parameter designates the name of the schedule which is used to update the SnapMirror relationships.
-policy <sm_policy>- SnapMirror Policy-
This parameter designates the name of the SnapMirror policy which is associated with the SnapMirror relationships.
[-auto-initialize {true|false}]- Auto Initialize-
This optional parameter specifies whether or not initializes of the SnapMirror relationships should be started after the relationships are created. The default value for this parameter is
true. [-destination-volume-prefix <text>]- Destination Volume Name Prefix-
This optional parameter designates the prefix for the destination volume name. For example if the source path is of the form
vserver:volumeand the destination-volume-prefix specified isprefixand no destination-volume-suffix is specified, then the destination volume name will be_prefix_volume_dstor possiblyprefix_volume_1_dstif a name conflict is encountered. If both prefix and suffix are specified asprefixand__suffix, then the destination volume name will beprefix_volume_suffixorprefix_volume_1_suffix, if a name conflict is encountered. [-destination-volume-suffix <text>]- Destination Volume Name Suffix-
This optional parameter designates the suffix for the destination volume name. If you do not desginate a suffix, a destination volume name with suffix
dst_will be used. For example if the source path is of the formvserver:volume, and the suffix specified isDP_, the destination volume will be created with the namevolume_DPorvolume_1_DPif a name conflict is encountered. If both prefix and suffix are specified asprefixandsuffix, then the destination volume name will beprefix_volume_suffixorprefix_volume_1_suffix, if a name conflict is encountered.
To establish SnapMirror protection for the source volumes vs1.example.com:dept_eng1 and vs1.example.com:dept_eng2 using destination-vserver vs2.example.com and policy MirrorAllSnapshots type the following command:
vs2.example.com::> snapmirror protect -path-list
vs1.example.com:dept_eng1,vs1.example.com:dept_eng2 -destination-vserver
vs2.example.com -policy MirrorAllSnapshots
