lun portset remove
Remove iSCSI/FCP LIFs from a portset
This command removes a LIF from a port set.
You cannot remove the last LIF in a port set if the port set is bound to an initiator group (igroup). To remove the last LIF in a port set, use the lun igroup unbind command to unbind the port set from the igroup. Then you can remove the last LIF in the port set.
This command is not supported for a Vserver with Infinite Volume. |
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
-portset <text>- Portset Name-
Specifies the port set you want to remove a LIF from.
-port-name <port_name>,…- LIF or TPG Name-
Specifies the LIF name you want to remove from the port set.
cluster1::> port set remove -vserver vs1 -portset ps1 -port-name lif1
Removes port lif1 from port set ps1 on Vserver vs1.
