storage automated-working-set-analyzer volume show
Displays the Automated Working Set Analyzer volume table
The automated-working-set-analyzer volume show command displays the volume statistics reported by the corresponding Automated Working-set Analyzer running instances.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node (privilege: advanced)-
This parameter indicates the node name that the AWA instance runs on.
 [-flash-cache {true|false}]- Flash Cache Node-wide Modeling (privilege: advanced)-
This parameter indicates whether the AWA is modeling flash-cache.
 [-vol-uuid <UUID>]- Uuid of the Volume (privilege: advanced)-
This parameter indicates the volume uuid that this command is issued on.
 [-aggregate <aggregate name>]- Aggregate (privilege: advanced)-
This parameter indicates the aggregate name that the AWA instance runs on.
 [-volume <volume name>]- Volume (privilege: advanced)-
This parameter indicates the volume name that this command is issued on.
 [-rank <integer>]- Cache Benefit Rank (privilege: advanced)-
This parameter indicates the rank of this volume among all volumes that would be most benefited by the modeled cache technology based on the AWA prediction.
 [-read-throughput {<integer>[Bps|KBps|MBps|GBps]}]- Read Throughput (privilege: advanced)-
This parameter indicates the maximum read throughput over an interval that AWA has observed from the storage disks for this volume.
 [-write-throughput {<integer>[Bps|KBps|MBps|GBps]}]- Write Throughput (privilege: advanced)-
This parameter indicates the maximum write throughput over an interval that AWA has observed to the storage disks for this volume.
 [-cacheable-read <percent>]- Cacheable Read (privilege: advanced)-
This parameter indicates the maximum percent of cacheable read over an interval that AWA has observed for this volume. Cacheable reads are non-sequential reads, i.e., the percentage of data reads that could have been cached.
 [-cacheable-write <percent>]- Cacheable Write (privilege: advanced)-
This parameter indicates the maximum percent of cacheable write over an interval that AWA has observed. Cacheable writes are random overwrites, percentage of disk writes that could have been cached.
 [-projected-cache-size {<integer>[KB|MB|GB|TB|PB]}]- Max Projected Cache Size (privilege: advanced)-
This parameter indicates the projected Flash Pool cache usage by this volume.
 [-projected-read-hit <percent>]- Projected Read Hit (privilege: advanced)-
This parameter indicates the percentage of blocks that could be read from the Flash Pool cache instead of HDDs for this volume.
 [-projected-write-hit <percent>]- Projected Write Hit (privilege: advanced)-
This parameter indicates the percentage of block overwrites that could go to the Flash Pool cache instead of HDDs for this volume.
cluster1::> cluster-1::*> storage automated-working-set-analyzer volume show Node FC Aggregate Volume Rank Read Thrupt Write Thrupt ------------- ----- ------------ ------------ ---- ------------ ------------ vsim1 false aggr0 vol0 1 230.47KBps 580.09KBps
