system cluster-switch show-all
Displays the list of switches that were added and deleted
The system cluster-switch show-all command displays configuration details for discovered monitored cluster switches and management switches, including switches that are user-deleted. From the list of deleted switches, you can delete a switch permanently from the database to re-enable automatic discovery of that switch.
[-fields <fieldname>,…] -
Selects the fields that have the specified name.
[-instance ]} -
Selects detailed information for all the switches.
[-device <text>]- Device Name (privilege: advanced)-
Selects the switches that match the specified device name.
[-address <IP Address>]- IP Address (privilege: advanced)-
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version (privilege: advanced)-
Selects the switches that match the specified SNMP version.
[-community <text>]- DEPRECATED-Community String or SNMPv3 Username (privilege: advanced)-
This parameter is deprecated and may be removed in a future release of Data ONTAP. Use -community-or-usernameinstead.Selects the switches that match the specified community string or SNMPv3 username.
[-community-or-username <text>]- Community String or SNMPv3 Username (privilege: advanced)-
[-discovered {true|false}]- Is Discovered (privilege: advanced)-
Selects the switches that match the specified discovery setting.
[-model {NX5010|NX5020|CAT2960|OTHER|NX5596|CN1610|CN1601|NX3132|OT5548|NX3132V|OT9332|NX3132XL}]- Model Number (privilege: advanced)-
Selects the switches that match the specified model number.
[-type {cluster-network|management-network}]- Switch Network (privilege: advanced)-
Selects the switches that match the specified switch type.
[-sw-version <text>]- Software Version (privilege: advanced)-
Selects the switches that match the specified software version.
[-is-monitoring-enabled-operational {true|false}]- Switch Monitoring Status (privilege: advanced)-
Selects the switches that match the specified operational monitoring status.
[-reason <text>]- Reason For Not Monitoring (privilege: advanced)-
Selects the switches that match the specified reason.
[-version-source <text>]- Source Of Switch Version (privilege: advanced)-
Selects the switches that match the specified version source (for example, from SNMP, CDP or ISDP).
[-serial-number <text>]- Serial Number of the Device (privilege: advanced)-
Selects the switches that match the specified serial number.
cluster1::> system cluster-switch show-all
Switch Type Address Model
SwitchA cluster 1.2.3.4 Nexus5010
Is Monitored: yes
Reason:
Software Version: Cisco IOS 4.1N1
Version Source: CDP
The example above displays the configuration of all cluster switches and management switches.
