system cluster-switch show-all
Displays the list of switches that were added and deleted
The system cluster-switch show-all command displays configuration details for discovered monitored cluster switches and management switches, including switches that are user-deleted. From the list of deleted switches, you can delete a switch permanently from the database to re-enable automatic discovery of that switch.
[-fields <fieldname>,…] -
Selects the fields that have the specified name.
[-instance ]} -
Selects detailed information for all the switches.
 [-device <text>]- Device Name (privilege: advanced)-
Selects the switches that match the specified device name.
 [-address <IP Address>]- IP Address (privilege: advanced)-
Selects the switches that match the specified IP address.
 [-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version (privilege: advanced)-
Selects the switches that match the specified SNMP version.
 [-community <text>]- DEPRECATED-Community String or SNMPv3 Username (privilege: advanced)-
This parameter is deprecated and may be removed in a future release of Data ONTAP. Use -community-or-usernameinstead.Selects the switches that match the specified community string or SNMPv3 username.
 [-community-or-username <text>]- Community String or SNMPv3 Username (privilege: advanced)-
 [-discovered {true|false}]- Is Discovered (privilege: advanced)-
Selects the switches that match the specified discovery setting.
 [-type {cluster-network|management-network}]- Switch Network (privilege: advanced)-
Selects the switches that match the specified switch type.
 [-sw-version <text>]- Software Version (privilege: advanced)-
Selects the switches that match the specified software version.
 [-is-monitoring-enabled-operational {true|false}]- Switch Monitoring Status (privilege: advanced)-
Selects the switches that match the specified operational monitoring status.
 [-reason <text>]- Reason For Not Monitoring (privilege: advanced)-
Selects the switches that match the specified reason.
 [-version-source <text>]- Source Of Switch Version (privilege: advanced)-
Selects the switches that match the specified version source (for example, from SNMP, CDP or ISDP).
 [-serial-number <text>]- Serial Number of the Device (privilege: advanced)-
Selects the switches that match the specified serial number.
 [-model <text>]- Model to display (privilege: advanced)-
Selects the switches that match the specified model number.
cluster1::> system cluster-switch show-all
  Switch                      Type               Address          Model
  SwitchA                     cluster            1.2.3.4          Nexus5010
        Is Monitored: yes
              Reason:
    Software Version: Cisco IOS 4.1N1
      Version Source: CDP
The example above displays the configuration of all cluster switches and management switches.
