ONTAP commands
system services firewall show
Show firewall status
The system services firewall show command displays firewall configuration and logging information. If the command is issued without any parameters, it displays information about all nodes in the cluster. You can also query specific nodes for their firewall information by running the command with the -node parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects information about the firewall settings on the node you specify.
[-enabled {true|false}] - Service Enabled
Selects information about the nodes with the firewall enabled ("true ") or disabled ("false ").
[-logging {true|false}] - (DEPRECATED)-Enable Logging
Note This parameter is deprecated and may be removed in a future version of Data ONTAP.
Selects information about the nodes with firewall logging enabled ("true ") or disabled ("false ").
The following example displays information about firewall configuration for all nodes in the cluster:
cluster1::> system services firewall show
Node           Enabled Logging
node0          true    false
node1          true    false
node2          true    false
node3          true    false
4 entries were displayed.
