vserver cifs domain password schedule show
Display the domain account password change schedule
The vserver cifs domain password schedule show command displays the domain account password change schedule configuration. It displays the following fields:
  • Vserver: Vserver for which the schedule is configured
  • Schedule Enabled: Whether the schedule is enabled or disabled for this Vserver
  • Schedule Interval: Weeks after which the password change schedule occurs again for this Vserver
  • Schedule Randomized Within: Minutes within which the schedule must begin for this Vserver
  • Schedule: Password change schedule currently set on this Vserver
  • Last Successful Password Change/Reset Time: Time at which the last password change or reset happened successfully on this Vserver
  • Warning: Warning message, applicable only when the change password job is deleted with the feature still enabled on this Vserver
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information for the specified Vserver.
[-is-schedule-enabled {true|false}] - Is Password Change Schedule Enabled
If you specify this parameter, the command displays information for all the Vservers on which the is-schedule-enabled value applies.
[-schedule-weekly-interval <integer>] - Interval in Weeks for Password Change Schedule
If you specify this parameter, the command displays information for all the Vservers on which the schedule-weekly-interval value applies.
[-schedule-randomized-minute <integer>] - Minutes Within Which Schedule Start Can be Randomized
If you specify this parameter, the command displays information for all the Vservers on which the schedule-randomized-minute value applies.
[-schedule-last-changed <text>] - Last Successful Password Change/Reset Time
If you specify this parameter, the command displays information for all the Vservers on which the schedule-last-changed value applies.
[-schedule-description <text>] - Schedule Description
If you specify this parameter, the command displays information for all the Vservers on which the schedule-description value applies.
[-schedule-warn-msg <text>] - Warning Message in Case Job Is Deleted
If you specify this parameter, the command displays information for all the Vservers on which the schedule-warn-msg value applies.
The following example shows the domain account password change schedule configuration when the password change feature is enabled for Vserver vs1.
cluster1::> vserver cifs domain password schedule show
Vserver: vs1
Schedule Enabled: true
            Schedule Interval: 4   week
   Schedule Randomized Within: 120 min
                     Schedule: Fri@23:00
              Last Changed At: Thu Apr  4 02:35:23 2013
The following
