network qos-marking show
Display the QoS marking values
The network qos-marking show command displays the QoS marking values for different protocols, for each IPspace.
[-fields <fieldname>,…] -
Use this parameter to display only certain fields of the QoS marking table.
[-instance ]} -
Use this parameter to display all the fields of the QoS marking table.
[-ipspace <IPspace>]- IPspace name-
Use this parameter to display the QoS marking entries for the specified IPspace.
[-protocol <text>]- Protocol-
Use this parameter to display the QoS marking entries for the specified protocol. The possible values are NFS, CIFS, iSCSI, SnapMirror, NDMP, FTP, HTTP-admin, HTTP-filesrv, SSH, Telnet, and SNMP.
[-dscp <integer>]- DSCP Marking Value-
Use this parameter to display the QoS marking entries matching the specified DSCP value. The possible values are 0 to 63.
[-is-enabled {true|false}]- Is QoS Marking Enabled-
Use this parameter to display the QoS marking entries matching the specified flag.
The following example displays the QoS marking entries for the Default IPspace.
cluster1::> network qos-marking show -ipspace Default
IPspace Protocol DSCP Enabled?
Default
CIFS 10 false
FTP 48 false
HTTP-admin 48 false
HTTP-filesrv 10 false
NDMP 10 false
NFS 10 true
SNMP 48 false
SSH 48 false
SnapMirror 10 false
Telnet 48 false
iSCSI 10 false
11 entries were displayed.
