network qos-marking show
Display the QoS marking values
The network qos-marking show
command displays the QoS marking values for different protocols, for each IPspace.
[-fields <fieldname>,…]
Use this parameter to display only certain fields of the QoS marking table.
[-instance ]
Use this parameter to display all the fields of the QoS marking table.
[-ipspace <IPspace>]
- IPspace name-
Use this parameter to display the QoS marking entries for the specified IPspace.
[-protocol <text>]
- Protocol-
Use this parameter to display the QoS marking entries for the specified protocol. The possible values are NFS, CIFS, iSCSI, NVMe-TCP, SnapMirror, SnapMirror-Sync, NDMP, FTP, HTTP-admin, HTTP-filesrv, SSH, Telnet, and SNMP.
[-dscp <integer>]
- DSCP Marking Value-
Use this parameter to display the QoS marking entries matching the specified DSCP value. The possible values are 0 to 63.
[-is-enabled {true|false}]
- Is QoS Marking Enabled-
Use this parameter to display the QoS marking entries matching the specified flag.
The following example displays the QoS marking entries for the Default IPspace.
cluster1::> network qos-marking show -ipspace Default IPspace Protocol DSCP Enabled? ------------------- ----------------- ----- -------- Default CIFS 10 false FTP 48 false HTTP-admin 48 false HTTP-filesrv 10 false NDMP 10 false NFS 10 true SNMP 48 false SSH 48 false SnapMirror 10 false SnapMirror-Sync 10 false Telnet 48 false iSCSI 10 false NVMe-TCP 10 false 12 entries were displayed.
