network qos-marking show
Display the QoS marking values
The network qos-marking show command displays the QoS marking values for different protocols, for each IPspace.
- { [-fields <fieldname>,…]
Use this parameter to display only certain fields of the QoS marking table.
- | [-instance ]}
Use this parameter to display all the fields of the QoS marking table.
- [-ipspace <IPspace>]- IPspace name
Use this parameter to display the QoS marking entries for the specified IPspace.
- [-protocol <text>]- Protocol
Use this parameter to display the QoS marking entries for the specified protocol. The possible values are NFS, CIFS, iSCSI, SnapMirror, SnapMirror-Sync, NDMP, FTP, HTTP-admin, HTTP-filesrv, SSH, Telnet, and SNMP.
- [-dscp <integer>]- DSCP Marking Value
Use this parameter to display the QoS marking entries matching the specified DSCP value. The possible values are 0 to 63.
- [-is-enabled {true|false}]- Is QoS Marking Enabled
Use this parameter to display the QoS marking entries matching the specified flag.
The following example displays the QoS marking entries for the Default IPspace.
cluster1::> network qos-marking show -ipspace Default
IPspace             Protocol           DSCP  Enabled?
Default
                    CIFS                 10  false
                    FTP                  48  false
                    HTTP-admin           48  false
                    HTTP-filesrv         10  false
                    NDMP                 10  false
                    NFS                  10  true
                    SNMP                 48  false
                    SSH                  48  false
                    SnapMirror           10  false
                    SnapMirror-Sync      10  false
                    Telnet               48  false
                    iSCSI                10  false
12 entries were displayed.
 PDFs
PDFs
