qos statistics volume resource disk show
Display disk resource utilization data per volume
The qos statistics volume resource disk show command displays the disk utilization for volumes per node. The disk utilization shows the percentage of time spent on the disk during read and write operations. The command only supports hard disks.
The command displays the following data:
  • The QoS volume name (Workload)
  • The QoS workload ID (ID)
  • Disk utilization (Disk)
  • The number of HDD data disks utilized (Number of HDD Disks)
The results displayed are sorted by total disk utilization. Each iteration starts with a row that displays the total disk utilization across all volumes.
-node {<nodename>|local} - Node
Selects the volumes that match this parameter value.
