storage aggregate inode-upgrade show
PDF of this doc site
Creating your file...
Display inode upgrade progress
The storage aggregate inode-upgrade show
command displays information about aggregates undergoing the inode upgrade process. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the default fields about all aggregates undergoing the inode upgrade process. The default fields are:
aggregate
status
scan-percent
remaining-time
space-needed
scanner-progress
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-aggregate <text>]
- Aggregate Name-
If this parameter is specified with the
-node
parameter, the command displays detailed information about the specified aggregate. If only this parameter is specified, the command displays information about all aggregates that match the specified name. [-node <nodename>]
- Node Name-
If this parameter is specified, the command displays information only about the aggregate or aggregates that are located on the specified node.
[-status {pending|scanning|suspended-initalizing|suspended|cleanup-pending|cleanup|cleanup-done|suspended-aborting|suspended-removing|suspended-while-removing|suspended-ironing}]
- Upgrade Status-
If this parameter is specified, the command displays information only about the aggregate or aggregates that match the specified inode upgrade status.
[-scan-percent <percent>]
- Upgrade Scan Percent Complete-
If this parameter is specified, the command displays information only about the aggregate or aggregates that match the specified inode upgrade progress percentage.
[-space-needed {<integer>[KB|MB|GB|TB|PB]}]
- Space Needed to Complete Upgrade-
If this parameter is specified, the command displays information only about the aggregate or aggregates where the space needed to complete the upgrade process matches the specified size.
[-remaining-time <[<integer>h][<integer>m][<integer>s]>]
- Remaining Upgrade Time-
If this parameter is specified, the command displays information only about the aggregate or aggregates where the remaining time to complete the inode upgrade process matches the specified time.
[-scanner-progress <text>]
- Scanner Progress-
If this parameter is specified, the command displays information only about the aggregate or aggregates where the progress of the inode upgrade process matches the input.
The following example displays information about all aggregates undergoing the inode upgrade process:
cluster1::> storage aggregate inode-upgrade show Aggregate Status %Complete Time Remaining Space Needed Inode Progress --------- --------- --------- -------------- ------------ -------------- aggr0 pending 0% - 20.36MB Public : Inode 0 out of 65562 aggr1 pending 0% - 19.84MB Public : Inode 0 out of 63714
