network fcp zone show
Display the active zone set information
Displays the active zone set information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to select the active zone set information for adapters that located on the node name that you specify.
 [-adapter <text>]- Adapter-
Use this parameter to select the active zone set information for the specified adapter.
 [-zoneset-name <text>]- Zoneset Name-
Use this parameter to select the active zone set information for the specified zone set name.
 [-zone-name <text>]- Zone Name-
Use this parameter to select the active zone set information for the specified zone name.
 [-unique <integer>]- Unique-
A unique index for each zoneset record.
 [-type-name <text>]- Type Name-
Use this parameter to select the active zone set information with the specified symbolic type.
 [-type <integer>]- Type-
Use this parameter to select the active zone set information with the specified port type.
 [-port-id <Hex Integer>]- Member Port Id-
Use this parameter to select the active zone set information with the specified member port id.
 [-domain-id <integer>]- Member Domain Id-
Use this parameter to select the active zone set information with the specified member domain id.
 [-port <integer>]- Member Port-
Use this parameter to select the active zone set information with the specified member port.
 [-wwn <text>]- Member WWN-
Use this parameter to select the active zone set information with the specified member WWN.
 [-zone-count <integer>]- Zone Count-
Use this parameter to select the active zone set information with the specified number of zones.
 [-zone-member-count <integer>]- Zone Member Count-
Use this parameter to select the active zone set information with the specified number of zone members in a zone.
cluster1::> network fcp adapter zone show
                                          Member
                       Zone Name          Type                WWN
Active Zone Set on adapter 0c
   Zone Set Name: zoneset_name
                       zone_name_1        Port ID             -
                       zone_name_2        Domain ID/Port      -
                       zone_name_3        Fabric Port Name    00:00:00:00:00:00:00:00
                       zone_name_3        Fabric Port Name    01:00:00:00:00:00:00:00
                       zone_name_3        Fabric Port Name    02:00:00:00:00:00:00:00
9 entries were displayed.
The example above displays information regarding active zone set information for the cluster.
