system node show-memory-errors
Display Memory Errors on DIMMs
system node show-memory-errors prints the history of memory (storage controller's RAM) errors since boot. This command can be useful in diagnosing memory problems or determining which DIMM, if any, might need replacement. Some correctable ECC errors are to be expected under normal operation, but many occurring on a particular DIMM might indicate a problem. All the fields are read only and can be used to filter the output. The maximum number of physical address and timestamps reported is 160.
[-fields <fieldname>,…] -
If you specify the
[-verbose ](privilege: advanced) -
The
-verboseparameter enables verbose mode, resulting in the display of more detailed output. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
When provided, the
-nodeparameter specifies the nodes for which the memory error statistics are to be displayed. When the-nodeis not provided, the command is applied to all the nodes in the cluster. [-id <integer>]- DIMM ID (privilege: advanced)-
This parameter refers to the DIMM ID. It can be used to look at the correctable ECC error count on a specific DIMM.
[-name <text>]- DIMM Name (privilege: advanced)-
This parameter specifies the DIMM name for which the memory error statistics are to be displayed.
[-cecc <integer>]- Correctable ECC Error Count (privilege: advanced)-
This parameter can be used to get all the DIMMs with the specified correctable ECC error count.
[-merr {true|false}]- Multiple Errors on Same Address (privilege: advanced)-
Use this parameter with the values true to specify whether the error was seen multiple times on the same physical address. It can also be used to look at all the DIMMs with multiple errors on same address.
[-timestamp <text>,…]- Error Time (privilege: advanced)-
This specifies the time at which the error was seen on the DIMM.
[-addr <text>,…]- Error Address (privilege: advanced)-
This specifies the physical address on which the error was seen.
cluster1::*> system node show-memory-errors
Correctable ECC Memory Errors:
Node: localhost
DIMM CECC Multiple Err
Name Count Same Address
DIMM-1 0 false
DIMM-2 0 false
DIMM-3 0 false
DIMM-4 0 false
DIMM-5 4 true
DIMM-6 1 false
DIMM-7 1 false
DIMM-8 0 false
8 entries were displayed.
cluster1::*> system node show-memory-errors -verbose
Node: localhost
DIMM CECC Multiple Err Physical
Name Count Same Address Timestamp Address
DIMM-1 0 false - -
DIMM-2 0 false - -
DIMM-3 0 false - -
DIMM-4 0 false - -
DIMM-5 4 true 12/02/2013 08:17:43 0xD640
12/02/2013 08:17:57 0x3F7FF800
12/02/2013 08:18:03 0x11743D000
12/02/2013 08:18:37 0x11743D000
DIMM-6 1 false 12/02/2013 08:17:53 0x87EC0
DIMM-7 1 false 12/02/2013 08:17:51 0x13DED8900
DIMM-8 0 false - -
