statistics disk show
Disk throughput and latency metrics
This command continuously displays performance data for disks at a regular interval. The command output displays data in the following columns:
  • Disk - disk name.
  • Node - node name.
  • Busy (%) - percentage of time there was at least one outstanding request to the disk.
  • Total Ops - total operations per second.
  • Read Ops - read operations per second.
  • Write Ops - write operations per second.
[-disk <text>] - Disk
Selects the disk for which you want to display performance data.
[-node {<nodename>|local}] - Node
Selects the node for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies the maximum number of disks to display. The default setting is 25.
The following example displays disk statistics:
cluster1::> statistics disk show
cluster1 : 12/31/1969 16:00:04
                   Busy *Total Read Write
 Disk         Node  (%)    Ops  Ops   Ops
 VMw-1.31    node2    0      2    2     0
 VMw-1.30    node2    0      3    0     3
 VMw-1.3     node1    0      0    0     0
 VMw-1.29    node2    0      1    0     1
