system node autosupport check show
Display overall status of AutoSupport subsystem
The system node autosupport status check show command displays the overall status of the AutoSupport subsystem.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node-
Selects the nodes that match this parameter value. This parameter specifies the node whose status is being displayed.
 [-http-status {ok|warning|failed|not-run}]- Overall Status of AutoSupport HTTP/HTTPS Destinations-
Selects the nodes that match this parameter value. This parameter specifies whether connectivity to the AutoSupport HTTP destination was established.
 [-aod-status {ok|warning|failed|not-run}]- Overall Status of AutoSupport OnDemand Server-
Selects the nodes that match this parameter value. This parameter specifies the detailed description of the connectivity status to the AutoSupport OnDemand Server.
 [-smtp-status {ok|warning|failed|not-run}]- Overall Status of AutoSupport SMTP Destinations-
Selects the nodes that match this parameter value. This parameter specifies whether connectivity to the AutoSupport mailhost was established.
 [-config-status {ok|warning|failed|not-run}]- Overall Status of AutoSupport Configuration-
Selects the nodes that match this parameter value. This parameter specifies whether the AutoSupport configuration check succeeded or not.
 [-warning-text <text>]- Conditional Warning Message-
Selects the nodes that match this parameter value. This parameter specifies how to get more details regarding the status of the AutoSupport subsystem, in case of any errors.
The following example displays the overall status of the AutoSupport subsystem on a node named node2:
cluster1::> system node autosupport check show -node node2
On Demand Server SMTP Configuration ---------- ---------- ------------- ok ok ok
