system node show
Display the list of nodes in the cluster
The system node show command displays information about the nodes in a cluster. You can limit output to specific types of information and specific nodes in the cluster, or filter output by specific field values.
To see a list of values that are in use for a particular field, use the -fields parameter of this command with the list of field names you wish to view. Use the system node modify command to change some of the field values that this command displays.
[-fields <fieldname>,…] -
If you specify the
[-inventory ] -
Use this parameter to display inventory information such as serial numbers, asset tags, system identifiers, and model numbers.
[-messages ] -
Use this parameter to display system messages for each node.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information for node names that match this parameter value.
[-owner <text>]- Owner-
Selects nodes that have owner values that match this parameter value.
[-location <text>]- Location-
Selects nodes at specific physical locations that match this parameter value.
[-model <text>]- Model-
Selects nodes that have model numbers that match this parameter value.
[-serialnumber <text>]- Serial Number-
Selects nodes that have serial numbers that match this parameter value.
[-assettag <text>]- Asset Tag-
Selects nodes that have asset tags that match this parameter value.
[-uptime {<seconds>|[<d> days] <hh>:<mm>[:<ss>]}]- Uptime-
Selects nodes that have uptimes that match this parameter value. This parameter is most useful when used with a range indicator such as less than or greater than, as in:
show -uptime >"30 days 00:00"
[-nvramid <nvramid>]- NVRAM System ID-
Selects nodes that have NVRAM system IDs that match this parameter value.
[-systemid <text>]- System ID-
Selects nodes that have system IDs that match this parameter value.
[-vendor <text>]- Vendor-
Selects nodes that have vendor names that match this parameter value.
[-health {true|false}]- Health-
Selects nodes that have health values that match this parameter value. Specify
trueto display healthy nodes, andfalseto display unhealthy nodes. [-eligibility {true|false}]- Eligibility-
Selects nodes that have voting eligibility values that match this parameter value.
[-epsilon {true|false}]- Epsilon (privilege: advanced)-
Selects nodes that have epsilon holding designations that match this parameter value. This is useful to find out which node, if any, in the current cluster has been designated as epsilon. Specify
trueto display the node holding epsilon, andfalseto display nodes not holding epsilon. [-uuid <UUID>]- UUID (privilege: advanced)-
Selects nodes that have the specified universal unique identifiers that match this parameter value.
[-is-diff-svcs {true|false}]- Differentiated Services-
If true, the corresponding node is considered to be part of differentiated services storage infrastructure.
[-is-all-flash-optimized {true|false}]- All-Flash Optimized-
Selects nodes that have "All-Flash Optimized" personality values that match this parameter value. Specify
trueto display nodes which support only SSD drives, andfalseto display nodes which support all kinds of drives.
The following example displays information about all nodes in the cluster:
cluster1::> system node show Node Health Eligibility Uptime Model Owner Location ------ ------ ----------- ------------- -------- ------ ------------- node0 true true 89 days 23:47 MODELXX IT Data Center 2 node1 true true 15 days 22:37 MODELXX Data Center 2 node2 true true 15 days 23:00 MODELXX Data Center 2 node3 true true 15 days 22:37 MODELXX Data Center 2 4 entries were displayed.
This example displays the locations and model numbers of all nodes that are in physical locations that have names beginning with "Lab":
cluster1::> system node show -location lab* -fields location, model node location model ------------- -------- ------ node5 Lab 1 MODELXX node7 Lab 3 MODELXX node9 Lab 5 MODELXX
