vserver migrate show-volume
Display status of volumes in a migrating Vservers
This command displays status of all the volumes in a migrating Vservers.
- { [-fields <fieldname>,…]
This specifies the fields that need to be displayed.
- | [-instance ]}
If this parameter is specified, the command displays detailed volume status information.
- [-vserver <vserver name>]- Vserver Name (privilege: advanced)
Name of the Vserver which is migrating.
- [-volume <volume name>]- Volume Name (privilege: advanced)
If this parameter is specified, the command displays detailed volume status information that matches specified volume.
- [-volume-dsid <integer>]- Volume DSID (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified DSID.
- [-volume-msid <integer>]- Volume MSID (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified MSID.
- [-vserver-uuid <UUID>]- Vserver UUID (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified Vserver UUID.
- [-node <nodename>]- Node (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified node.
- [-state {Transfer | ReadyForCutover | PreCutover | Penultimate | CutoverStarted | CutoverComplete | Cleanup | MigrateFailed}]- Status of the transfer (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified vserver migrate status.
- [-last-transfer-duration <integer>]- Duration of last transfer in seconds (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified last transfer duration.
- [-last-transfer-done {true|false}]- Is the last transfer done (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified last transfer done flag status.
- [-break-done {true|false}]- Is the break done (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified break-done flag status.
- [-errors <text>]- Errors in volume operation if any (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified errors.
- [-last-transfer-queue-time <MM/DD/YYYY HH:MM:SS>]- Time of the last transfer (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified last transfer queue time.
- [-transfer-completed {true|false}]- Is the transfer completed (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified transfer completed flag status.
- [-cutover-transfer-count <integer>]- Number of transfers within cutover threshold (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified cutover transfer count.
- [-force {true|false}]- Volume force cutover flag (privilege: advanced)
If this parameter is specified, the command displays the details of volume status that matches specified volume force cutover flag.
cluster1::> vserver migrate show-volume -vserver test
 PDFs
PDFs
