system services ndmp service stop
Stop the NDMP service
The system services ndmp service stop command stops the NDMP service daemon on a node. This is a disruptive command and should not be used in normal scenarios. Processing of active sessions continues but the ability to view or kill sessions is lost. This is different from the system services ndmp off command. The system services ndmp off command disables new NDMP connections on the node but does not stop the NDMP service daemon. This command is not supported on Infinite Volumes.
-node {<nodename>|local}- Node (privilege: advanced)-
The node on which the NDMP service needs to be stopped.
cluster1::*> system services ndmp service stop -node node0
Stops the NDMP service on node0.
