system cluster-switch delete
Delete information about a cluster switch or management switch
The system cluster-switch delete command disables switch health monitoring for a cluster or management switch.
-device <text>- Device Name-
Specifies the name of the switch.
[-force <true>]- Force Delete (privilege: advanced)-
Specifies if force delete or not.
cluster1::> system cluster-switch delete -device SwitchA
Disables monitoring for the switch named SwitchA.
cluster1::> system cluster-switch delete -device SwitchA -force
Forcefully disables monitoring for the switch named SwitchA. (privilege: advanced)
