network ndp neighbor delete
Delete a static NDP neighbor entry
The network ndp neighbor delete command deletes a static Neighbor Discovery Protocol (NDP) neighbor from a Vserver.
-vserver <vserver name> - Vserver Name
Use this parameter to specify the Vserver on which the NDP neighbor is to be deleted.
-neighbor <IP Address> - Neighbor Address
Use this parameter to specify the neighbor’s IPv6 address.
The following example deletes a NDP neighbor entry within Vserver vs0.
cluster1::*> network ndp neighbor delete -vserver vs0 -neighbor 20:20::20
