vserver iscsi interface show
Show network interfaces used for iSCSI connectivity
This command shows the iSCSI logical interfaces for a specified Vserver. If you do not specify any of the parameters, the command displays all of the interfaces on a Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Use this parameter to display iSCSI logical interfaces that match the Vserver that you specify.
[-lif <lif-name>]- Logical Interface-
Use this parameter to display iSCSI logical interfaces that that you specify.
[-status-admin {up|down}]- Administrative Status-
Specifies the configured status of the logical interface. If you set this parameter to up, the command displays all iSCSI logical interfaces with the administrative status of up. If you set this parameter to down, the command displays all the iSCSI logical interfaces with the administrative status of down.
[-status-oper {up|down}]- Operational Status-
Specifies the current status of the logical interface. If you set this parameter to up, the command displays all the iSCSI logical interfaces with the operational status of up. If you set this parameter to down, the command displays all the iSCSI logical interfaces with the operational status of down.
[-enabled {true|false}]- Enabled-
Specifies if this logical unit is enabled for iSCSI service. If you enter this command without a parameter, its effective value is true, and the command displays all the enabled iSCSI logical interfaces.
[-address <IP Address>]- IP Address-
Use this parameter to display iSCSI logical interfaces that match the IP address that you specify.
[-ip-port <integer>]- IP Port Number-
Use this parameter to display iSCSI logical interfaces that match IP port number for the logical interface that you specify.
[-curr-node <nodename>]- Current Node-
Use this parameter to display iSCSI logical interfaces that match current node that you specify.
[-curr-port {<netport>|<ifgrp>}]- Current Port-
Use this parameter to display iSCSI logical interfaces that match specified current physical port that you specify.
[-is-home {true|false}]- Is Home-
Specifies if the node hosting the logical interface is the initially configured node. If you use this command without using this parameter, it is set to true, and the command displays all iSCSI interfaces that are on the initially configured node.
[-tpgroup <text>]- TPGroup Name-
Use this parameter to display iSCSI logical interfaces that match the target portal group name that you specify.
[-t, -tpgroup-tag <integer>]- TPGroup Tag-
Use this parameter to display iSCSI logical interfaces that match the target portal group tag that you specify.
[-relative-port-id <integer>]- Relative Port ID-
Use this parameter to display the iSCSI logical interface that matches the relative target port ID that you specify. The system assigns each logical interfaces and target portal group a relative target port ID that is Vserver unique. You cannot change this ID.
[-sendtargets-fqdn <text>]- iSCSI Discovery SendTargets FQDN (privilege: advanced)-
Use this parameter to display the iSCSI logical interfaces that match the iSCSI Discovery SendTargets Fully Qualified Domain Name (FQDN) that you specify.
The following example displays information for logical interfaces on Vserver vs_1.
cluster1::> vserver iscsi interface show -vserver vs_1
Logical Status IP Curr Curr
Vserver Interface TPGT Admin/Oper Address Node Port Enabled
vs_1 vs_1.iscsi 1027 up/up 10.63.8.165 node1 e0c true
vs_1 vs_1.iscsi2
1028 up/up 10.63.8.166 node1 e0c true
2 entries were displayed.
The following example displays the logical interface vs_1.iscsi with the relative target port ID of 1.
cluster1::> vserver iscsi interface show -vserver vs_1 -relative-port-id 1
