vserver data-policy export
Display a data policy
The vserver-data policy export command displays the current data policy for a Vserver with Infinite Volume.
-vserver <vserver name>- Vserver Name-
This specifies the Vserver with Infinite Volume for which the data policy will be displayed.
The following example shows the current data policy.
cluster1::> vserver data-policy export -vserver vs1
{ "ruleset_format_version" : "1.0",
"rules" : [
{ "rule_label" : "default",
"rule_id" : "ec17a05f-7785-11e1-baf4-123478563412",
"rule_scope" : [],
"rule_epoch" : { "epoch_reference" : "ctime" },
"rule_epochs" : {
"0" : {
"local" : {
"metadata" : {
"storageservice" : "-"
