vserver group-mapping delete
Delete a group mapping
The vserver group-mapping delete command deletes a group mapping.
The vserver group-mapping delete command is not supported on Vservers with FlexVol volumes.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver from which you want to delete the group mapping.
-direction {krb-unix|win-unix|unix-win}- Name Mapping Direction-
This parameter specifies the direction of the group mapping that you want to delete.
-position <integer>- Position-
This parameter specifies the position of the group mapping that you want to delete. Specify the position as a positive integer.
The following example deletes a group mapping on a Vserver named vs1. The group mapping is from UNIX to Windows and is at position 5.
cluster1::> vserver group-mapping delete -vserver vs1 -direction unix-win -position 5
