network routing-groups route delete
(DEPRECATED)-Delete a static route
This command has been deprecated and may be removed from a future version of Data ONTAP. Use the "network route" command set to configure routes instead. |
The network routing-groups route delete command deletes a static route from a routing group. You can delete routes originating from specified Vservers, and routes within specified routing groups.
-vserver <vserver>- Vserver Name-
Use this parameter to specify the node or Vserver from which the route will be deleted.
-routing-group <text>- Routing Group-
Use this parameter to specify the name of the routing group within which you want to delete the route.
-destination <IP Address/Mask>- Destination/Mask-
Use this parameter to specify the IP address and subnet mask of the route you want to delete. The format for this value is: address, slash ("/"), mask. For example,
0.0.0.0/0is a correctly formatted value for the -destination parameter.
The following example deletes a route within routing group d192.0.2.167/24 originating from Vserver node3.
cluster1::> network routing-groups route delete -vserver node3 -routing-group d192.0.2.167/24 -destination 0.0.0.0/0
