system cluster-switch threshold show
Display the cluster switch health monitor alert thresholds
The system cluster-switch threshold show command displays thresholds used by health monitor alerts.
cluster1::> system cluster-switch threshold show
Per 0.10% values: 1 = 0.10%, 5 = 0.50%
In Errors Threshold (%) Out Errors Threshold (%)
1 1
Displays the inbound and outbound switch interface packet error thresholds are set at 0.1%. The node platform health monitor also shares the same thresholds in monitoring packet errors of cluster ports on the node.
